sumped fuel tank?
Old Feb 21, 2003 | 11:42 PM
383 Blwn Bird's Avatar
sumped fuel tank?
Guys, I'm pulling out my gas tank and fuel lines to install a cage, while it's out I would like to sump the stock tank. Who has done this? What needs to be done to prep the tank for welding and cutting. Any help would be great!
Kevin
Old Feb 21, 2003 | 11:54 PM
rskrause's Avatar
Moderator
Frankly, the tank is hard to weld. It's thin sheet metal. That's a job I'd have someone else do who is an expert welder. Then it's their problem getting every trace of gas outa the tank! Some people fill the tank with water, others flood it with inert gas prior to welding. This can be dangerous if not done properly.
Rich Krause
Old Feb 22, 2003 | 12:57 AM
Thanks for the reply, I'm a very proficient welder/fitter my question is how do people get rid of the gas vapor. And yes I would back shield it with argon.
Thanks again Kevin
Old Feb 22, 2003 | 05:50 AM
rskrause's Avatar
Moderator
If you like, I can check with my friend Buddy (who does this kind of thing and will be doing mine in a couple of weeks). But as I said, the two methods I know about are filling the tank with argon or water before welding. Of course, thoroughly clean it out first!
Rich Krause
Old Feb 22, 2003 | 05:03 PM
Thanks Rich, I'd be very greatful for the help...........!
Kevin
Old Feb 22, 2003 | 06:44 PM
rskrause's Avatar
Moderator
Kevin
I will ask him on Monday, he wasn't at the shop today.
Rich Krause
Old Feb 23, 2003 | 12:51 AM
zturbo's Avatar
My welder has the customer wash out the fuel tank prior to bringing it in. He then washes it out again upon arival making sure no vapor is left in the tank. Then welds it up with the tig and no problems.
Steven
Old Feb 23, 2003 | 11:13 AM
1st and goal's Avatar
You can always take the tank to a radiator shop to have it flushed.
Marc
Strick
May 26, 2015 11:41 AM
4586
Apr 24, 2015 01:03 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
guionM
9
Aug 29, 2002 01:48 PM
guionM
18
Jul 11, 2002 01:45 AM
