Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
which octane do you use?
Old Nov 20, 2011 | 11:05 AM
97z28k&N's Avatar
Question which octane do you use?
Hey everyone, I am curious as to what octane you run in your lt1/ls1. I currently run 89 because filling a tank of 92 every week is kind of .....scary expensive... i've never had knocking either.
Old Nov 20, 2011 | 04:17 PM
Re: which octane do you use?
You won't hear knock with low octane fuel. The knock sensor will pick it up before you hear it, and the PCM will pull ignition timing, reducing engine power. The only way to know if its knocking (and losing performance) would be to put a scanner or scanning software on it, and see if the PCM is pulling timing.
Old Nov 22, 2011 | 10:34 PM
97z28k&N's Avatar
so, if there were to be any knock, would it do any damage or would it just be a performance loss?
Old Nov 24, 2011 | 11:12 AM
The knock sensor hears the onset of knock, long before it can do damage to the engine, and retards the timing. You will only lose performance.
Old Nov 24, 2011 | 11:21 AM
6SpdLT1Z's Avatar
I run 91 or 92 (depending on the gas station) in my LT1.
87 in my truck
Old Nov 24, 2011 | 12:58 PM
97z28k&N's Avatar
I put in a tank of 93 yesterday, sure runs a lot better!
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
kahouna23
V6 Tech
Feb 10, 2003 06:08 AM
frankjr8
Feb 8, 2003 11:03 PM
camaro98_speed
Dec 14, 2002 03:50 PM
