no fule pueresser
no fule pueresser
well when i turn the key on the pump works but i get no puersser gague kinda bounces a little but nothing iam running the msd fule pump with the Aeromotive A1000-6 Injected Bypass Regulators. i have the main fule line coming off the tank going to the left side port and the from there off the right side port it gose to the fule rail. need help!!!
You need to run your return lines into the the FPR so that it can regulate the fuel pressure while it is in the fuel rails. As it stands you are regulating the pressure before it even gets to the rails and afterwards it is just being dumped back into the tank via the return line.
edit: should my lines be ran like this the main line off the tank should it go to the fule rail then off the other fule rail run the line to the return port in the fpr and then fron the inlet port on the fpr to the gas tank>>?? i dunno just my guess
The supply line should run straight to the fuel rails. your return line coming from the fuel rails is going to go into the inlet of the FPR. From there return line to the tank will connect to the return port of the FPR.
So it should go like this:
Tank------Fuel Rails---Regulator-------Tank
