Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
No crank no lights
Old Sep 12, 2022 | 11:46 AM
Nick69's Avatar
No crank no lights
I have 95 z28 auto.I can run wire from bat to crank fuse and start right up. I can't get this ro run otherwise. New battery-coil-checked all the links and cleaned all the ground. If it starts from batt to crank fuse don't that eliminate ignition in colum and the switch? Were else can I check or bypass?
Old Sep 12, 2022 | 12:09 PM
Re: No crank no lights
You're back feeding the system somehow, bypassing the ignition switch. The "CRANK" fuse (3 amp) in the end of dash panel has only one purpose and that is to supply the DERM (Diagnostic Energy Reserve Module) that stores energy to fire the air bags. Has nothing to do with cranking the engine.
When you turn the key to the "START" position, the ignition switch feeds two wires on the ignition switch. The critical one is:
Connector 2 - Pin A - yellow wire feeds - 1) the starter circuit (through the clutch start or or auto trans position switch), 2) the theft deterrent relay (TDR), 3) the DERM
Sounds like the yellow wire or the contact in the ignition switch is not carrying power, but when you apply power to the "CRANK" fuse, you are back feeding the TDR and the starter solenoid circuit. You are bypassing the yellow wire and the ignition switch.
From Shoebox:
http://shbox.com/1/ignswschematic.jpg
mannycamaro
Oct 29, 2009 07:14 AM
firebirdjosh
3rd Gen / L98 Engine Tech
Aug 30, 2004 01:53 PM
Mir Hussain
Jan 15, 2004 09:04 PM
OutlawZ28
Aug 7, 2003 09:51 AM
MZK4252
Apr 2, 2003 04:06 PM
