Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
need help with possible ground problem ?
Old Nov 30, 2008 | 12:14 PM
hotheadbuddy's Avatar
Question need help with possible ground problem ?
i installed a stroked 396 in my 95 t/a . soon after the install my msd digital 6 went out and my new stereo head unit. i installed another head unit and it worked until i let the car sit for a week. i went to start it and the battery was dead and tested bad. i replaced the battery and the car runs fine after removing the msd box. but i still have some sort of issue and the only thing i can think of is a grounding problem. anyone run into a problem like this ? the block was painted and im sure i made sure the paint was scraped off where the grounds bolt on the passenger side of the engine . there is a little black wire by the starter that i could not find where it bolts to and need to know where it goes and if that wire could be at fault. i thought it was because i used a 4 bolt corvette block but could be wrong. thanks for any help and insite.
Old Nov 30, 2008 | 12:26 PM
Your problems are not caused by a 4-bolt block.... they are no different than the 2-bolt blocks, other than the extra bolts and main caps - same casting. That isn't going to cause electrical problems.
Have you checked Shoebox's website, which has the wiring diagrams for the 95's, harness photographs, etc?
http://shbox.com/1/4th_gen_tech1.html
Old Nov 30, 2008 | 12:29 PM
Thumbs up
ill check it. and thanks.
Critter
Jul 7, 2015 08:33 PM
eanhl2004
Apr 4, 2015 12:01 PM
BigWil
Mar 29, 2015 12:24 PM
blac94Z
Mar 20, 2015 09:58 PM
JSK333
Sep 9, 2002 10:33 PM
