Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Need Help ASAP: Fuel Pump
Old Feb 3, 2007 | 06:35 PM
1LESSZ28's Avatar
replacing mine and was thinking of putting in a walbro 255lph.
1. will the extra flow make my gas mileage worse? did anyone notice there's go down after the install?
2. Is it worthwhile to use this pump may car will only have heads/cam at most.
3. Will this fit my 97z? if not how do i modify it?
thanks in advance
Old Feb 4, 2007 | 06:09 AM
rskrause's Avatar
Moderator
It will make no difference at all and it isn't needed. OTOH, it will work fine and have extra flow available if you do need it art some point (like if you add nitrous, for example). So, if you need a new pump anyway, it's a fine choice. But don't expect any gain.
Rich
Old Feb 4, 2007 | 06:49 AM
lmt0705's Avatar
nice cheap insurance. you can never have too much fuel pump, not to mention you can get a 255 walbro for less than going to a part store and getting a crappy stock replacement
Old Feb 4, 2007 | 07:00 AM
rskrause's Avatar
Moderator
The stock pump is not crappy. OTOH, if you mean a no-name import from some el-cheapo parts store, I see your point.
Rich
Old Feb 17, 2007 | 11:40 AM
1LESSZ28's Avatar
Rich
what horsepower level would require the added flow? I am getting ported heads and a cam so around 400 at the wheels
Also, my sending unit is still good should I replace it or will it last? How much does a sending unit cost?
Old Feb 17, 2007 | 01:28 PM
myslowcamaro's Avatar
not sure what the limit is, i dyno'ed at 420rwhp at best and still using stock pump. i have a walboro 255 also, just havent gotten around to installing it.
Old Feb 17, 2007 | 02:00 PM
2000GTP's Avatar
Easy way of knowing if you stock fuel pump can handle the extra demands is to put a fuel pressure gauge on the car and check to see if there are any pressure dips under load.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
