Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
In-line fuel pump
Old Jul 19, 2008 | 08:24 PM
86Camarolt1's Avatar
In-line fuel pump
Is anyone running a Inline fuel pump, would this work with the fpr
Old Jul 20, 2008 | 08:20 AM
'94 Bad A Z28's Avatar
The only thing to worry about with an inline pump is that it is restricted to what your in-tank can push... unless you eliminate your in-tank pump.
Old Jul 20, 2008 | 10:37 AM
Actually, since the in-tank pump and the inline pump are now sharing the "pressure" creation, they will both flow a greater amount than they would if an individual pump was the only source for pressure. But that's not a good way to increase flow. That's a good way to increase the pressure capability of the system. And if your in-tank pump is dying, or dead, it isn't going to work at all.
And yes, the stock LT1 fuel pressure regulator can control a system consisting of a stock in-tank pump and an added inline pump.
Why do you want to add an inline pump?
I'll move this to the "Fuel and Ignition" forum......
Old Jul 20, 2008 | 02:04 PM
just was askin because my fuel pump is dying and I was trying to avoid dropping the tank. But I guess I will have to drop it afterall
Old Jul 20, 2008 | 10:45 PM
That's the point I was trying to get across.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
