Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
"Jumpering" the fuel pump
Old Dec 23, 2010 | 11:02 AM
94QuasarZ's Avatar
I recently heard this phrase and am wondering what it means and how you do it. I'm looking for different ways to troubleshoot my fuel pump as I think mine is bad, any help or info would greatly be appreciated.
Old Dec 23, 2010 | 12:05 PM
RUDEDOG's Avatar
Re: "Jumpering" the fuel pump
Fuel pump prime connector on pass side shock tower. Put 12 volts on it and pump should run.
Old Dec 23, 2010 | 03:59 PM
http://shbox.com/1/fuel_pump_prime.jpg
Bypasses the fuel pump relay, and hence the PCM "permits".
Old Jan 27, 2011 | 11:25 AM
flyboyike's Avatar
Speaking of the fuel pump relay, I can't seem to find it on my '96 Z-28. The Haynes manual says it should have one, but I don't see it either under the hood or in the dash panel. Where is it?
Old Jan 27, 2011 | 11:35 AM
450hplt1's Avatar
Its under the kick panel where you would rest your left foot while driving.
Old Jan 27, 2011 | 11:37 AM
flyboyike's Avatar
Well, son of a gun, whatever is it doing there? I'll take a look and report back.
Old Jan 27, 2011 | 04:08 PM
You really need to bookmark Shoebox's website. He has a ton of info on the LT1's:
http://shbox.com/1/fuel_pump_relay.jpg
http://shbox.com/1/4th_gen_tech1.html
Old Mar 4, 2011 | 06:47 PM
ramosj88's Avatar
Is the location the same on a 1988 5.0 TPI? If not, where would it be?
Also I would like to put 12 volts as close to the pump I can to be sure the pumps the problem.
Is it the same as putting it on the primer.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
