Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Ignition switch
Old Mar 7, 2022 | 01:12 PM
blac94Z's Avatar
Ignition switch
Hey how’s it going you guys, I just need to know what does the black connector with the single orange wire go to on the ignition switch on the column ?
Old Mar 7, 2022 | 05:08 PM
Re: Ignition switch
The ignition switch diagram shows two connectors at the ignition switch:
C1 - pin A, orange. Nothing else.
C2 - 4 wires - red, brown, pink, yellow
http://shbox.com/1/ignswschematic.jpg
Not sure where the connector is for rhe turn signals, headlights, and other things that route to the bottom of the column.
The factory service manual will have connector face diagrams and pinouts, with location. Free download if you don’t have it.
https://www.mediafire.com/?40mfgeoe4ctti
Old Mar 7, 2022 | 05:25 PM
blac94Z's Avatar
Re: Ignition switch
c1 pin A orange wire looks to go to the turn signal from the diagram you posted if I’m correct.
Old Mar 7, 2022 | 06:29 PM
Re: Ignition switch
I interpreted the question to be where the single wire connector plugs into the ignition switch. Appears that if he inserted the blue plug first, the black connector would only fit in the remaining pin holes one way - sort of like putting puzzle pieces together. But I could have missed the point…. not an unusual occurrence .
http://shbox.com/ignsw/pin.jpg
Old Mar 8, 2022 | 05:08 AM
blac94Z's Avatar
Re: Ignition switch
hey it’s no problem I really appreciate your help injuneer
Meen95z
Oct 10, 2011 11:35 PM
henryz28
Feb 22, 2010 03:04 AM
'86 350
3rd Gen / L98 Engine Tech
Aug 31, 2006 05:01 PM
snapperheaded
Apr 4, 2004 09:49 PM
Robert95z
Nov 22, 2003 12:40 AM
