Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Ignition Switch heat problem
Old Oct 9, 2011 | 08:45 PM
Meen95z's Avatar
Question Ignition Switch heat problem
On my 95' Trans Am I have put a ignition switch in again, its kinda hit of miss on weather it will work. This is number 3 in 3-4 years, but I hear and can see there is a heat issue at the blue plug. Is there a fix for it? Run heavy gauge wire or anything? Also where does the "pink" wire that gets hot connect too? One end is the switch, where is the other go too? Thanks
Old Oct 9, 2011 | 10:44 PM
Re: Ignition Switch heat problem
http://shbox.com/1/ignswschematic.jpg.
Making sure the connection is tight will help.
Old Oct 10, 2011 | 11:35 PM
Do you have any heavy aftermarket electrical loads wired directly through the ignition switch, when they should be wired via relays to limit the current in the ignition switch circuit?
Cam's maro
Mar 24, 2015 08:09 PM
robcarnut
Mar 20, 2015 03:40 PM
kksi
Feb 17, 2015 10:41 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
