Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump voltage
Old Jan 25, 2007 | 07:07 PM
ayers1967's Avatar
fuel pump voltage
Has anyone ever check voltage at there fuel pump? I have 12.5 volts. is that enough.
Thanks ayers1967
Old Jan 25, 2007 | 07:25 PM
Canada's Avatar
Yep...you should have battery voltage...or close to it....as you will loose a minor amount (about a half a volt) due to the natural resistance of wire.
You should also check it with a test light, this puts a load on the system.....I've dirty connections have 12 volt at the connector but not have enough current to spin the pump or light it up.
Old Jan 25, 2007 | 07:30 PM
ayers1967's Avatar
Thanks for the info, I have a new setup from rock valley and i cant get but 10psi out of it. Just wanted to check everything before i called them.
ayers1967
grabbem88
Mar 18, 2015 01:25 PM
Scottyboy
Feb 11, 2015 10:28 PM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
