Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump troubles>
Old Jan 18, 2007 | 01:33 PM
Angel_G_Z28's Avatar
fuel pump troubles>
i bought my z28 about 2 weeksago i haven't been able to drive it though cuz it's not running, i test drove it once a week prior to buying it, but now i'm getting no fuel to the fuel rail, which is more likely fuel pump failure or faulty relay?
Old Jan 18, 2007 | 02:53 PM
Guest47904's Avatar
Guest
All you need is a voltmeter to test either one.
Old Jan 18, 2007 | 04:25 PM
blackztpi's Avatar
you can obviously hear the fuel pump turn on. you can manually prime the fuel pump via the connector on the passenger side to make sure the fuel pump isn't running. check the fuel pump relay as it is an easy fix.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
