Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pump replacement
Old Jun 2, 2011 | 08:34 AM
rocknroler69's Avatar
Im going to be renaplcing my fuel pump in my 93 z28, and just wanted to hear from anyone who has done one and had any advice or anything to make the job a little easier.
Old Jun 2, 2011 | 08:48 AM
detroitlt1's Avatar
Re: Fuel pump replacement
If you go through the trunk and cut a whole it is the easiest install I have done. There are writeups all over the web on The dimensions for your cuts. Drill a pilot hole and either use good pair of tin snips or a air nibbler. I tried both and overall a good pair of wiss aviator clips worked great!
Old Jun 2, 2011 | 08:49 AM
detroitlt1's Avatar
http://camaroforums.com/forum/4th-ge...ap-door-61963/ here is a good writeup
Old Jun 2, 2011 | 08:51 AM
detroitlt1's Avatar
Make sure before you put the pump back in that you have all the hoses hooked up good. Make sure the power supply is clipped in and make sure the strainer is installed all the way. If you miss anything on the pump before you put it in you will be taking it right back out.
Old Jun 2, 2011 | 05:14 PM
We have a "Fuel & Ignition" forum. That's where this belongs, not on "engine" tech. I'll move your post to the correct forum.
Old Jun 6, 2011 | 05:52 AM
Cool thanks. Is this done in the deepest part of the trunk?
Old Jun 6, 2011 | 08:16 AM
Or is it the higher part right behind the back seat?
Old Jun 6, 2011 | 12:05 PM
Did you read the sticky at the top of this forum for instructions?
Scottyboy
Feb 11, 2015 10:28 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
