fuel pump removal problem
so i cut the access hole like the link from here says and the feul pump will not come out it has metal fuel lines and will not move around i can lift it uop and down but not back and forth is there something im missing here am i still gonna have to drop the fuel tank .....please help
i used the info on the sticky but it does not say how to disconnect the fuel lines or show pics in one pic it looked like the lines were cut is that what you have to do is there any pics of someone disconnecting the lines ?
When I do this, I track where the lines go on top of the tank and I cut an extra flap on the top left out to make it easier to disconnect the lines, the usual instructions online don't show that part, but it makes it easier. Firstly, make sure that you have properly relieved fuel pressure, and just in case when disconnecting these 4 lines (2 rubber that just slip off the metal lines on the other end, 2 metal with plastic disconnect clips), wear safety glasses anyhow to prevent being blasted in the eyes by fuel (though not likely). These lines are a quick disconnect but aren't always easy because they are close together. They are just two sided flaps, pinch them both down and pull the lines connected to the pump apparatus, one at a time, have a rag handy as fuel will likely come out despite having relieved pressure. IIRC, you may have to push inward as you pinch the clips in and then pull. I find a flathead screw driver helps on one end, with your finger on the other to release a tricky one, but don't be too aggressive and break the clip.
