Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump removal problem
Old Jan 16, 2010 | 02:36 PM
ghost stripes's Avatar
so i cut the access hole like the link from here says and the feul pump will not come out it has metal fuel lines and will not move around i can lift it uop and down but not back and forth is there something im missing here am i still gonna have to drop the fuel tank .....please help
Old Jan 16, 2010 | 03:22 PM
RamAir95TA's Avatar
Maybe a dumb question, but did you disconnect the fuel lines? You should be able to see them at the top left of the hole. Two are quick-release, the other two are vent lines and are slip-fit.
Old Jan 16, 2010 | 03:31 PM
edz97's Avatar
I cut the hole on mine a little more to the left and to the front to access the fuel line connections.
Old Jan 16, 2010 | 03:59 PM
Did you use the information "stickied" at the top of the "Fuel and Ignition" forum?
That's where this should have been posted.
Old Jan 16, 2010 | 08:39 PM
i used the info on the sticky but it does not say how to disconnect the fuel lines or show pics in one pic it looked like the lines were cut is that what you have to do is there any pics of someone disconnecting the lines ?
Old Jan 16, 2010 | 09:01 PM
MarcR94v6's Avatar
When I do this, I track where the lines go on top of the tank and I cut an extra flap on the top left out to make it easier to disconnect the lines, the usual instructions online don't show that part, but it makes it easier. Firstly, make sure that you have properly relieved fuel pressure, and just in case when disconnecting these 4 lines (2 rubber that just slip off the metal lines on the other end, 2 metal with plastic disconnect clips), wear safety glasses anyhow to prevent being blasted in the eyes by fuel (though not likely). These lines are a quick disconnect but aren't always easy because they are close together. They are just two sided flaps, pinch them both down and pull the lines connected to the pump apparatus, one at a time, have a rag handy as fuel will likely come out despite having relieved pressure. IIRC, you may have to push inward as you pinch the clips in and then pull. I find a flathead screw driver helps on one end, with your finger on the other to release a tricky one, but don't be too aggressive and break the clip.
Old Jan 16, 2010 | 09:05 PM
thanks i got some more cutiing to do to get to the clips thanks very much this is what i needed
Old Jan 16, 2010 | 09:17 PM
http://www.cardomain.com/ride/348183/9
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
