Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Pump
Old Jul 9, 2012 | 03:08 PM
  #16
DomsZ28's Avatar
Re: Fuel Pump
When I opened the rear hatch and lifted the carpet there was a square someone cut out covered in tape. I peeled back the tape and saw the fuel pump RIGHT underneath the tape. Not the filter the PUMP....I have 30 days to return the regulator so if it doesnt solve it I can always return it. When I removed the vacuum line from the regulator I smelled fuel in the vacuum line which leads me to believe it is the regulator. But we will see.
Old Jul 9, 2012 | 05:17 PM
  #17
Re: Fuel Pump
Originally Posted by DomsZ28
Well after looking around my car I noticed under the carpet there was a big square someone cut out. And boom there was the filter. But anyway I ordered the Fuel pressure regulator on RockAuto for $43 shipped. So hopefully that will solve my problems.
I'm just going by what you typed, which didn't make much sense.
If the hatch is sealed with "tape" you might want to cut an oversize metal panel, and install it with numerous pop-rivets or sheet metal screws and some good sealer. With only tape, in an accident, you're going to have fuel in the passenger compartment.
Old Jul 9, 2012 | 05:43 PM
  #18
DomsZ28's Avatar
Re: Fuel Pump
Yeah sorry about the misunderstanding. My bad, shoula been more clear. Anyway your right Im going to try and find a better way to seal it. But im going to wait until I know for sure that the regulator will/wont fix it.
Old Jul 12, 2012 | 10:35 PM
  #19
DomsZ28's Avatar
Re: Fuel Pump
Ok I installed the FPR and here is the deal....The car still takes a few tries to fire up on a COLD start, but after that, it always fires right up on the first try...So the problem seems half fixed..What would cause that? Fuel pump?
Old Jul 14, 2012 | 12:01 PM
  #20
DomsZ28's Avatar
Re: Fuel Pump
I also replaced the Fuel filter and checked injectors for leaks
Old Jul 14, 2012 | 02:01 PM
  #21
mrmint69's Avatar
Re: Fuel Pump
Did you test the fuel pressure first start of the day and then again after to see if the pressure was the same including the drop in pressure after? I used to have a weak battery after sitting all night, but the car would start but not as good after driving and fully recharging the battery. You could check the battery and alternator to eliminate them. If you get fuel pressure in the acceptable range for all the test, then its time to look else where.
Old Jul 14, 2012 | 07:08 PM
  #22
Re: Fuel Pump
There was a list of 5 possible problem. Appears you ruled out three of them - FPR and leaking injectors.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
