Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pressure lt1
Old Oct 20, 2008 | 08:58 AM
mkent's Avatar
fuel pressure lt1
I'm working on getting a Lonnie's Dual pumper setup to replace my stock pump, but my fuel pressure gauge caught my eye on the way to work today.
When I'm cruising and going up small hills, my fuel pressure will hold as high as 48psi. Is it suppose to do that? I thought it was suppose to hold 43.5 psi... It only does this when I'm not seeing boost.
Old Oct 20, 2008 | 07:56 PM
Are you running the stock fuel pressure regulator? Does it still have the vacuum line connected? What is the fuel pressure with the vacuum line removed?
Old Oct 25, 2008 | 10:58 AM
Lonnie Pavtis's Avatar
Depending on the type of regulator & the way it was adjusted, you can see more pressure than stock at idle. But normal driving pressure should not increase, unless you are running both pumps continuously & overloading the small stock type regulator. Stock regulators do not have sufficient capacity for large fuel pumps & typically pick up approx 2# at idle. This is typical on LT1 & LS1 cars.
Also many supercharged cars can see positive boost at medium throttle, increasing the pressure. This can increase the pressure slightly, but most boost gauges are not highly responsive during the first 1-2# boost to notice it.
Give me a call. I'll be glad to help you out. I'm sure it is nothing major.
DirtyDaveW
Dec 1, 2016 05:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
Nostang 96z
Sep 10, 2002 08:54 PM
IDOXLR8
Aug 6, 2002 12:30 PM
