Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Pressure Gauge Install Fittings
Old Sep 20, 2011 | 09:30 AM
Red97LT1's Avatar
What fitting(s) are needed to install a FP gauge onto the fuel rail schrader valve? Is it the 1/8 to -4AN fitting? Where to buy? Depending on the sender size,will it just sit on top of the schrader valve or would I have to relocate it somewhere? What have you guys done?Thanks
Old Sep 21, 2011 | 07:34 AM
koolaid_kid's Avatar
Re: Fuel Pressure Gauge Install Fittings
I wanted to retain (and have used occasionally) my schrader valve under the hood. I used a T fitting and a couple of adapters to do this. The up side is that I can connect my Hypertech fuel pressure gauge under the hood to verify the pressure against my in-dash Autometer gauge. The down side is that it must be removed to remove/install the fuel rails. Also, I retained my fuel rail schrader valve, unlike most which require that the valve itself be removed from the fuel rail.
Caspers Electronics, a schrader tee part #102071 Click here
Earls 1/8 NPT coupling part #991001 Click here Click Here
Earls -4 to 1/8 NPT adaptor part #916104 Click here
Basically, the T fitting, a gender bender and an adapter.
Old Sep 21, 2011 | 12:12 PM
Red97LT1's Avatar
http://www.metcomotorsports.com/prod...p?prod=MFF0001
Old Sep 21, 2011 | 11:34 PM
If you are mounting the entire gauge directly to the Schrader valve, be careful. The Schrader fitting is only swaged onto the metal line, and will break off very easilly. If the gauge is near the cowl, the engine might torque enough to allow the gauge to hit the cowl.
I used an NOS 17535 -4AN 90-deg swivel fitting. That allows you to tighten the fitting onto the Schrader valve and aim it in the correct direction, away from the cowl and firewall, with no over-tightening. Then a braided SS hose with -4AN female on one end and 1/8" male NPT on the other (I've seen these ready-made on ebay). Use a 1/8" NPT brass coupling to connect the gauge to the hose, or insert a brass "tee" in the middle to provide an "extra" connection for some other purpose, as noted above.
Or.... the ultimate solution - pressure sender mounted directly to a bung welded to the passenger side fuel rail:
http://www.injuneer.com/images/photo...ls%20-%202.jpg
http://www.injuneer.com/images/photo...ilFuelConn.jpg
Old Sep 22, 2011 | 09:56 AM
Red97LT1's Avatar
Old Sep 22, 2011 | 10:02 AM
Red97LT1's Avatar
Here's what I have found so far...what do you think
Hose
Coupler
NOS
I should have said the electric sender for the gauge,not the actual gauge.
Old Sep 22, 2011 | 07:26 PM
Looks good to me.
Old Sep 22, 2011 | 07:29 PM
Red97LT1's Avatar
Looks good to me.
Thanks for the head up on the fuel rail valve. It would have been a pain if that valve snapped off due to the weight of the sending unit.
Old Sep 29, 2011 | 08:30 PM
Red97LT1's Avatar
Looks good to me.
Did you use any sort of sealer on the threads?
Old Sep 30, 2011 | 12:00 PM
NJ-LE's Avatar
There is enough straight section of metal fuel supply tubing (3/8") outboard of the lines' manifold support bracket to cut in a 3/8" compression tee. The tee and whatever fitting to go from 3/8" male tube to the necessary pipe thread adapter for the FP sender can be found at a Lowes, Home Depot or any dedcent plumbing supply house. At least on a 1995 and I assume it's still the same for a 97 LT1.
Old Oct 1, 2011 | 12:39 PM
The NPT threads should be sealed with teflon paste. Nothing should be used on the -AN fittings.
DirtyDaveW
Dec 1, 2016 05:37 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Burn_Out
Aug 18, 2002 08:49 AM
