Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Icm won't ground with heat sink
Old Sep 30, 2011 | 07:39 AM
grabbem88's Avatar
I have been through 4 icm's the past 6 months.
One of them I know for a fact was my old one from before!
I think I killed one for not using the heat sink
Anyways my icm bracket was stripped so I put nuts on the back to draw the bolt in. I ended up bending the bracket upper lip out and that is the only reason I think why everytime I try to reinstall the heat sink the icm doesn't ground????
I went to a different store and bought another icm and the car would not start with the heat sink on. Took it off car fires right up
So could somebody help explain to me another option or an idea of fixing it?
Old Sep 30, 2011 | 07:52 PM
Re: Icm won't ground with heat sink
If your heat sink is bent, it won't be able to make even contact with the ICM (which is important). Tightening the ICM down on a bent heat sink may damage the ICM or cause the electronics inside to flex and break connections. I'd get a new heat sink to start with.
BTW, the ICM grounds through the harness-not the heat sink. The heat sink is there to dissipate heat and thermal compound is used between the ICM and sink.
Old Sep 30, 2011 | 11:42 PM
grabbem88's Avatar
Glad you responded. The bracket is bent not the heat sink. But when I have the heat sink on the car won't start but when I take it off and just put the icm on bracket it starts and does not die.
I always do the test on your site every time this happens and everything checks out. So I am sending my ecu out to get rebuilt for more reasons than this issue.
Thanks for explaining the ground thing but something isn't right and I'm missing something
Old Oct 1, 2011 | 12:41 PM
Maybe the black wire in your ICM harness connector is not providing the required ground. Check the connector pins, check the continuity of the black wire to ground.
Old Oct 1, 2011 | 05:02 PM
grabbem88's Avatar
By ohms right?
I might of wiggled wire just right and that could be my reason.
Stay tuned
One more thing could my ecu be acting up
Old Oct 2, 2011 | 09:47 PM
grabbem88's Avatar
I got it running with heat sink. Plus I added washers too. Weird things happen to me
Critter
Jul 7, 2015 08:33 PM
bowtieboy95
Jul 1, 2015 06:49 AM
ad356
Apr 11, 2015 11:12 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Omega9
Aug 2, 2002 12:33 AM
