Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pressure is dropping at wot
Old Jul 18, 2007 | 08:59 AM
  #16
Originally Posted by markinkc69z
God, your quest is such horse****.
A "faulty" fuel pressure regulator would leak, not drop pressure at wot. You really aren't very strong technically when it comes to parts.
Thanks for the kind words.
Of course that fuel flowing through the diaphragm, out the vacuum compensation line, and into the intake manifold wouldn't cause any drop in fuel pressure - or would it? Or let's say the "fault" in the AFPR is that it can't close down all the way..... but hey... the fact it can't fully close off the return flow wouldn't drop pressure..... or would it?
You just can't accept the fact the Aeromotive AFPR is a POS. I made sure I didn't even mention the name because I knew you'd be trolling around at the mere mention of Aeromotive, but the thing is so bad, other people know it too.
Have a nice day in fairy-tale land
Old Jul 18, 2007 | 04:20 PM
  #17
mdacton's Avatar
Originally Posted by red 95 z28 lt1
ok took the camaro out for a quick ride today and fuel pressure is at 37-38 psi and its staying there doesent drop when i lay into the gas in first second and third, so im gonna say its the regulator? what adjustable regulator do you guys reccomend, i dont wanna drive it unless i have the regulator set to what it was for the tune
thanks for all the help
I'm not sure about the different brands, I will comment on the few I have had experience with....I had a metco, I used it for 6 years worked great.
My buddy had an accel..he had problems
Now I use an aeromotive external regulator...works fine.
My other buddy uses an external Weldon.....its top of the line
Old Jul 18, 2007 | 08:22 PM
  #18
Lonnie Pavtis's Avatar
One thing to consider is that you could hold only 43psi with the aftermarket regulator.
Now that you have the stock regulator, it holds steady, but at a lower pressure.
I would bet that your Aeromotive may hold the same lower pressure at a steady rate as well. This test would not prove a regulator at fault unless the stock regulator could hold pressure at 43psi or more for comparison.
Old Jul 19, 2007 | 06:20 AM
  #19
red 95 z28 lt1's Avatar
this problem was first noticed when on the dyno and it was set at 42psi the tuner said that it was dropping 10 to 15 psi and running too lean as well (should of mentioned that) so im sure pressure was dropping lower then stock fuel pressure
Old Jul 19, 2007 | 12:23 PM
  #20
mzgp5x's Avatar
I had a leaking Aeromotive FPR. Was a real problem and took a while to T_shoot. Don't like their design of the diaphram. Leaked alot of fuel thru the boost ref line to the intake manifold.
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Burn_Out
Aug 18, 2002 08:49 AM
