FMS 36lb injectors
FMS 36lb injectors
I bought some used 36 lb injectors but the clip that holds the injector to the fuel rail won't clip in the second groove it will clip in the first groove but I don't know if it is setting far enough down in the fuel rail. Do I need differnt clips or what? Also is there any way to make sure they are 36 and not 30lb. The part # is F1SE-E5A the other side is 290 280 150 945. Thanks
i put the 30 lbs. on my lt1, and used the groove that the clip fit into. I modified the other groove to accept the clip, but the injectors sat too high in the rail to seal in the intake. So yes, use the groove the clips fit into.
autoxr166
Sep 25, 2015 04:21 PM
