Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Pressure
Old Sep 14, 2008 | 12:03 AM
  #16
600hplt1sm's Avatar
Ok I know this is going to be a stupid question, but i was looking at a diagram today and it showed you running your existing fuel line into a "Y" block and then running 2 supply lines into each fuel then coming out of the other end of the fuel rail and into a regulator that has a return line on the bottom of it. Is this right. I thought the fuel went through the regulator before the rails.
Old Sep 14, 2008 | 01:40 PM
  #17
The diagram is correct. In a "recirculated" fuel system, the fuel pressure regulator is on the return side, not on the supply side. FPR opens and closes to control the fuel pressure by controlling how much fuel returns to the tank. Stock LT1 fuel system is recirculated, with the FPR on the return side.
Old Sep 14, 2008 | 06:41 PM
  #18
600hplt1sm's Avatar
OK. Injuneer you mentioned earlier about the fuel heating up. I noticed today that now with my canton valve covers the fuel lines are actually laying on the valve covers. Would that be a problem do you think. I actually have now put them above my STB but i don't know if that might be a issue
Old Nov 2, 2008 | 11:24 PM
  #19
600hplt1sm's Avatar
Ok, Update on this issue. I just installed the racetronix kit. & im using the stock regulator. The same problems seem to occur. But not as bad. I drove the car for an extended period yesterday and crusing in 3rd gear @ 55MPH my rpm was around 3000. My boost gauge showed 20IN vaccumn steady. After about a mile the A/F ratio started to go way lean and the FP started to flucuiate & you could hear a slight backfire / mis. If i let off the throttle just a little it starts to go back to normal. Would a bad inline booster pump cause a issue like this. I have changed the filter. Does anyone have a suggestion
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
