Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel cell ?
Old Apr 20, 2008 | 08:14 AM
BMoney's Avatar
fuel cell ?
does anyone here have a fuel cell in there car? if so do you have any pics of it. I was trying to use my stock tank and add a -12 bung in the tank for my fuel line, but not sure if it will work or not. so I am thinking of switching to a fuel cell. let me know whatcha got, and how you blocked it from the driver compartment. thanks
Old Apr 20, 2008 | 10:08 AM
Wolfe makes a screw-in aluminum panel (rear bulkhead) that replaces the flip up hatch well cover, that they claim meets NHRA tech:
http://www.wolferacecraft.com/detail.aspx?ID=783
I have some pics of a fuel cell install in a 97, but its a convertible, so there was no need for the bulkhead.
I use the stock tank, with one pump in the stock location, and a second pump connected to a -10AN fitting welded to the rear/bottom of the tank. Works fine. But there are internals added to the tank over the fitting, and I don't know the details because I was not there when the shop welded them up, and put the tank back in the car.
Old May 3, 2008 | 08:02 PM
BMoney's Avatar
what I was wanting to do worked. here are a couple pics of what i did. it turned out great. welded on a -12 bung to the tank for my feed line, and a -8 for my return line. mounted the pump in the bottom rear of the hatch.
Old May 3, 2008 | 08:03 PM
BMoney's Avatar
sorry the pics are so small, I took them with my phone.
Old May 5, 2008 | 04:21 PM
What kind of a firewall are you using for the hatch area, since the fuel pump and lines appears to be mounted there?
Old May 7, 2008 | 04:08 PM
BMoney's Avatar
I am getting the one from wolfe racecraft. or I just might make my own. not sure yet
Old May 8, 2008 | 09:50 AM
97ChameleonTA's Avatar
Moderator
I'm using this, it mounts in the factory location.
Old May 8, 2008 | 09:14 PM
BMoney's Avatar
wow. that is a nice piece! whats the price on that thing?
Old May 11, 2008 | 09:39 AM
Moderator
It isn't cheap. I got mine a long time ago but now they are running around $675 from NastyPerformance.com.
DirtyDaveW
Dec 1, 2016 05:37 PM
NewsBot
May 16, 2015 04:00 PM
cmyname1
Feb 19, 2015 08:38 PM
BLOWNBIRD
May 28, 2003 01:02 AM
BIGCOWL-IMP
Jul 22, 2002 04:26 PM
