Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Cutting access hole for fuel pump (convertible)
Old Aug 17, 2013 | 09:09 PM
  #16
JFR's Avatar
JFR
Re: Cutting access hole for fuel pump (convertible)
Toby, will try when I am done.
Old Aug 18, 2013 | 02:39 PM
  #17
bobdec's Avatar
Found this.. [autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2798& transactionid=1376854799-76105113163&posted_by=bobdec_www.camaroz28.com&you tube_video_id=NEwcRG5hhFk[/autostream]
Old Aug 18, 2013 | 03:57 PM
  #18
JFR's Avatar
JFR
Thanks so much bobdec///
Nice video....
frank
Old Aug 23, 2013 | 12:46 PM
  #19
JFR's Avatar
JFR
Bob Dec
What do you use to disconnect the hard lines that were hard to get too?
I assume the tool I used to remove the fuel lines at the fuel rail are the same?
I was wondering, I see 4 lines coming out of fuel assembly, , fuel out, fuel return, vapor to engine, where does the other one go to?
Thanks for your great pictures.
Frank
Old Aug 23, 2013 | 05:14 PM
  #20
bobdec's Avatar
Sorry not my video, found it after searching and posted the link for reference.. I have never replaced a fuel pump. Also my car is not a vert.
Old Aug 24, 2013 | 12:01 PM
  #21
The vapor vent line goes to the charcoal canister, not directly to the engine. The fourth line is for the fuel tank vent (pressure/vacuum relief) valve.
Courtesy of Shoebox:
http://shbox.com/1/fuel_pump_wiring.jpg
Old Sep 8, 2013 | 12:43 PM
  #22
JFR's Avatar
JFR
My 1st attemp to post pictures.
Picture of my tank cut, I cut a little bit more on edge to get to the connectors.
will bend back and put a plate over it.
http://www.wa6bth.com/camaro/tank%20mod.jpg
2nd picture. I added a plug , so I can pull the whole unit out and work on bench.
http://www.wa6bth.com/camaro/plug%20added.jpg
3rd picture Installed and hooked up. I cut the hard lines and used fuel injector fuel line and make sure to use 4 clamps. I did not and had to add 2.
http://www.wa6bth.com/camaro/installed.jpg
hope these pictures will help someone else out. I can probably pull the pump assembly in less that 20 mins now.
1995 Z28 LT1 Convertible
Frank
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
