Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
changing the fuel pump?
Old Mar 17, 2010 | 06:58 PM
1996greenZ28's Avatar
Ok what is the best way of changing the fuel pump in a 96 camaro.
Old Mar 17, 2010 | 06:59 PM
and if i buy an external fuel pump will that be better and do i still have to drop the tank,
Old Mar 17, 2010 | 07:03 PM
scr0tum's Avatar
There are 2 ways to install a new fuel pump. You can search the boards to find out.
One involves dropping the fuel tank and replacing the pump. The other involves cutting a hole in the bottom of the car to access the fuel tank.
Old Mar 17, 2010 | 07:05 PM
"Best" is subjective. You have two choices: drop the tank or cut an access hole in the rear floor (there is a sticky in the fuel/ignition forum). An external pump will do no good if the internal pump does not work, so you can't get by without getting into the tank.
Old Mar 17, 2010 | 08:41 PM
so should i cut a hole is what u r saying? where is the best place to cut?
Old Mar 17, 2010 | 09:42 PM
Look at the sticky in the fuel and ignition forum, please. Cutting is your choice.
Old Mar 17, 2010 | 09:53 PM
As Shoebox noted, there is a "sticky" in the topic listing for the "Fuel and Ignition" forum. This thread should have been posted on that forum, since the "LT1 Based Engine Tech" forum is only for engine topics.
I'll move your post to the Fuel and Ignition forum.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Deadbolt24
Jan 19, 2015 01:29 PM
ANDYZ28
Dec 29, 2014 09:13 PM
30thZ4C
Dec 26, 2014 05:09 PM
