Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
96Z won't start
Old Aug 11, 2011 | 03:38 PM
Yoges_96_Z28's Avatar
96Z won't start
I've been reading a few post but haven't came up with the exact issue I'm having.
I was driving the other day to the gas station. I was low on Gas but not completely out. As i pulled up to a light my car started *sputtering and shaking, knocking* really loud. It died out on me, but when i hit the ignition it started back up, but doing the same rattling and sputtering. I though I had ran out of gas. so i pushed it in to the gas station and put $20 just to ensure i didn't have problems. After fueling, i tried starting it and it started again, but still doing the same thing. The car would not respond if i hit the accelerator it would just sputter, shake and knock. The car would not respond to me pressing the pedal.. It did that a few times, now all the car does is crank it will not turn over. I thought it was the pump, but when i try to start it i can smell the gas.
could this be a bad Opti. or electrical issue?
Any help would really be appreciated...
Old Aug 11, 2011 | 05:11 PM
Re: 96Z won't start
Check the fuel pressure. The pump should prime to at least 40psi, shut off after 2 seconds, and hold that pressure or close to it for a while.
Old Sep 12, 2011 | 05:21 PM
Re: 96Z won't start
Turned out to be the Opti, Coil and Cap... changed them out and it fired right up..... Kind of would of been better if it was the fuel pump... what a PITA that was.....
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
