Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 Z28 LT1 Fuel Pump Prime Wire
Old Sep 2, 2019 | 07:06 PM
chevykid's Avatar
Does the fuel pump prime wire go directly to the fuel pump?
Because i look at the wire and it doesn't look like it could handle the current of the fuel pump, look like a relay control wire.
And what value of Ohm's should you get to ground?
Thanks!
Old Sep 2, 2019 | 08:02 PM
Re: 95 Z28 LT1 Fuel Pump Prime Wire
You need to use Shoebox's site:
http://shbox.com/1/1995_pcm3.jpg
http://shbox.com/1/fuel_pump_prime.jpg
The factory service manual wiring diagram shows the gage of each wire.
deereman79
Sep 2, 2010 01:16 PM
Mike96z
Mar 12, 2008 02:18 PM
limige
Sep 5, 2005 07:57 AM
krazwag
Sep 2, 2004 04:05 PM
OBDIICamaro
Oct 4, 2003 12:31 PM
