how to wire a boost a pump
Old Sep 2, 2004 | 06:23 AM
krazwag's Avatar
Heres my problem. I hooked up my msd boost a pump but, I'am not sure which wire you tie in on the fuel pump relay. I tied into the pink wire on the relay on the floor of the drivers side right beside the cluth pedal. I think thats the fuel pump relay. Anyway It's almost like it's wired direct because when the car is running the fuel pressure is 42psi. As soon as I touch the wire running from the boost a pump relay to the fuel pump relay the pressure jumps to 52. Could somebody tell me which wire to tie into on the fuel pump relay. thanks
Old Sep 2, 2004 | 04:05 PM
krazwag's Avatar
Re: how to wire a boost a pump
I'am sure somebody on here has used a bap. I did a few searches but nothing on the exact wire that needs to be splices. thanks
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Skull Leader
Aug 10, 2002 11:01 AM
