Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 Z28 #11 Ignition fuse blown
Old Sep 15, 2018 | 11:01 AM
james franklimn's Avatar
As I was leaving a parking lot, I put my 95 Z28 in neutral and revved it a bit and it died. It blew the #11 ignition fuse. when I jump the fuse the car runs and shifts fine. I tracked the small pink wire from the block to the split at the passenger rear of the engine compartment. It splits into a larger pink wire that does not get hot when the key is on. The small wire off the split goes down and on top of the trans. That wire does get hot. I cut that wire and the car wont start. I think that small wire goes to the TCC solenoids. The trans pan has not been off for a very long time. The car has 118,000 and the trans has about 20,000 miles on it. I put a 30 amp fuse in just to get home from about 3 miles and the small pink wire was smoking hot. Am I looking at replacing some solenoids? Thanks for any help
Old Sep 15, 2018 | 12:45 PM
Re: 95 Z28 #11 Ignition fuse blown
Fuse #11 related wiring:
Factory service manual download: - this will have the fuse block diagram reference on the Trans schematic below:
https://www.mediafire.com/?40mfgeoe4ctti
Courtesy of Shoebox
Trans
http://shbox.com/1/electronic_trans_controls.jpg
Ignition coil
http://shbox.com/1/95_ign_system_schematic.jpg
dirtgar
Oct 29, 2010 01:00 PM
neversummer
Apr 17, 2005 08:32 AM
DrewHMS97SS
Mar 9, 2005 12:45 PM
maxboosteric
Sep 24, 2004 08:02 PM
99TransAmWS6
Jun 17, 2004 12:39 PM
