Meziere wiring, where to put blue wire?
Old Apr 16, 2005 | 05:40 PM
neversummer's Avatar
I tried just sticking the blue wire in with the 10A ignition fuse in the engine fuse box. But that blew my fuse. Is there a favorite spot to splice this wire in? The only accy power wire I know of is the one for the radio. And if I splice into a wire that is on a fuse, won't that just blow that fuse because the total draw through the line would likely be more than the fuse is rated?
Old Apr 17, 2005 | 08:32 AM
magnumv8's Avatar
Re: Meziere wiring, where to put blue wire?
you need to wire it through a relay. I used the ignition feed at the coil to trigger the relay.
jayvar
Feb 2, 2015 10:00 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
GigaMp3z
Feb 20, 2003 02:57 PM
kandied91z
Aug 6, 2002 01:18 AM
