Will stock fans work with a D1 blower
Old Mar 14, 2010 | 07:55 PM
stephenpen's Avatar
Will stock rad fans work with a D1 blower ? I was going to stand my rad up but I can't hack-up my car like that.
Also I'm cutting a hole in the front bumper to feed the intercooler with fresh air. Will that make the car run cooler or is there not enough air flow to make a difference. I did remove all the plastics and washer bottle hoping it would help cooling.
Old Mar 14, 2010 | 10:16 PM
The SRZ's Avatar
Run fine w/ the factory stuff on my F1. Don't see why you'd be any different.
Old Mar 14, 2010 | 10:52 PM
fabgmc4me's Avatar
Everything fit fine with my D1SC and a 8 rib setup.
When I went to a F1a and a 12 rib, I had to hammer the frame, and move the radiator/fans forward just a bit.
Old Mar 15, 2010 | 01:24 PM
ramair96ws6's Avatar
I ran stock fans no hammer mods. I built alluminum spacers for the bolts on the driver side to move the fan closer to the radiator. it gave me the 1/4" i needed.
Old Mar 15, 2010 | 05:23 PM
RUNMYTA's Avatar
As ramair96ws6 said just make you some 1/4in spacers and move the fans closer to the radiator and you will be fine. I actually used a couple of aluminum tubing cut in 1/4 spacers for mine.
SpeedJunkee
Jan 27, 2015 10:02 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
Rich_z28
Aug 27, 2002 12:20 AM
