What's YOUR fuel pump of choice...???
Old May 28, 2006 | 11:43 PM
  #16
1BadAzzGT's Avatar
Re: What's YOUR fuel pump of choice...???
Bosch 420LPH. Plenty of pump.
Old May 29, 2006 | 02:00 AM
  #17
jasonisdn's Avatar
Originally Posted by Procharged94Lt1
Actually no- the pumps work just fine without having a pump to feed it. I have a Weldon on my car and it seems to work just fine-
so your in-line pump is the only one working? your intank has been removed? i was always was told if you have 2 pumps in series and 1 dies both are useless. if the intank dies no feed to the in-line, if the in-line dies it stops or majorly slows the flow. is this wrong or has pump advancedments take place where it will hang open like a therostat and allow fuel to pass by?
Old May 29, 2006 | 07:49 AM
  #18
97WS6Pilot's Avatar
I use a dual walbro 255lph. It is as quiet as stock. Some say it is good for up to 1000HP. Mine is a daily driver so I like having the redundancy of two pumps. Sort of like airplane fuel systems there are two of everything. First pump runs all the time. Second pump comes on at 5 psi. I can switch between primary and secondary with a switch in the drivers compartment.
I wish I would have had this system when my stock pump died at 90,000 miles. I had to low boy my car home from southern Kentucky.
Old May 30, 2006 | 07:06 AM
  #19
Procharged94Lt1's Avatar
By 'pumps' I was speaking more in general of the frame mounted bigger pumps instead of the two smaller in-tank pumps. I happen to be using a Weldon and there many people using the A1000 without too much trouble either.
Old May 30, 2006 | 07:35 AM
  #20
jasonisdn's Avatar
is your factory pump still in tank though?
Old May 30, 2006 | 08:22 PM
  #21
No- I don't have the intank pump- its out- there is a new feed line going to the bottom of the tank that is in place of the pump..
Old May 31, 2006 | 11:28 PM
  #22
ltlhomer's Avatar
Weldon makes good pumps. 2025 here.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
