Turbo install *nightmare* PTK / PTS LT1 front mount
Old Nov 22, 2007 | 01:13 AM
  #91
elchoclo's Avatar
Originally Posted by snorkelface
We are keeping the stock fans and putting in BeCool's most badass radiator for our cars. It is pretty much impossible to find without knowing the part number.
That radiator was a large chunk of change, but I don't want to chance it since the car will also see some road race duty.
How did you get clearance between the turbo and the radiator to fit the stock fans ? Did you get rid of the AC radiator? Is the BeCool thinner that the stock one? Because in my setup I just get with the stock radiator in place like half an inch of clearance.
I would really like to keep the stock ones they are a lot stronger than the crappy ones that PTK send me
Old Nov 22, 2007 | 06:59 PM
  #92
elchoclo's Avatar
I Finally Started The Car!!!!
Here"s a video of the first start! Sorry for all the bad jokes in it
http://youtube.com/watch?v=n3vhtqxB8Y0
Old Nov 22, 2007 | 07:43 PM
  #93
blown383's Avatar
I would be worried if my friends were grabbin' my crotch!
But other than that congrats on getting the car started!
-B
Old Nov 22, 2007 | 08:19 PM
  #94
97s10ondubs's Avatar
-B
x12037123978123, i'd be worried about the long haired one
Old Nov 22, 2007 | 10:14 PM
  #95
snorkelface's Avatar
If you look a couple pages back, you'll see that the radiator was moved forward over six inches. Very custom, but I needed to keep the AC too.
Old Jan 25, 2008 | 12:05 PM
  #96
TurboSS's Avatar
more progress
The car runs now and is just about ready fior the dyno
Screw in IAT sensor
weld in bung for the IAT and eld on mount for a man sized Blow Off Valve BOV. That mean all the PTK BOV provisions needed to be sealed.
Mike Haddad the shop owner is weary of trnas failure eo this little baby showed up on my bench. SFI stamped tranny blanket.
little items that are normally simple..
Like battery cables, starter wires, 02 sensors all be come burnable items!!!
Routing them is now a chore and protecting them a priority.
Old Jan 25, 2008 | 12:12 PM
  #97
TurboSS's Avatar
MORE!
keeping the passenger side 02 out of trouble
finished oil cooler pluming
fully wrapped and assembled turbo housing
what cant be seen here is I had to completly re fabricate the waste gate flangeS
PTK's flange 100% did not work or would it. CRAP CRAP CRAP.
Take a good look at the earlier pics of the head unit and what a joke this was for WG alignment. Boooo! thumbs down.
It all had to be re done on the NICE NICE.
another of the head unit
nice and pretty
Old Jan 25, 2008 | 12:16 PM
  #98
TurboSS's Avatar
MORE MORE MORE
One gauge to the starter and the old sarter wire to the alt.
that is some fat connection!
Starts great and charges great.
power and ground for the acceltronic injector converter is sneaking into the power junction and ground.
Mad props to LJ for the nice instructions.
I cranked it off and on w/o fule or spark to get the oil pressure up.
Dropped in the fuel and ignition fuses and this baby lit off for the first time in less than one full rotation!!
Old Jan 25, 2008 | 12:17 PM
  #99
chris96ta's Avatar
Nice to see the progress. About time to get that thing on the dyno.
Old Jan 25, 2008 | 12:20 PM
  #100
RealQuick's Avatar
Nice work dude. Thats a $hit ton of work for a bolt-in kit.
Jon
Old Jan 25, 2008 | 12:23 PM
  #101
TurboSS's Avatar
More pics later
Lots of cools stuff yet to post...
I did some trick pluming for the boost, eboost 2, fabbed suspension, custom wiring for the oil cooler fan into the relay box ,,,bla blaaa bla,,, and on and on.
Next step is the dyno.
And several hurdles await.
-2bar open loop speed density tune on a 97 PCM
has it ever been done before???!!!!
well it runs so far and holds AFR
-will the Pro Built Automatics Stage 2, drive shaft, and diff live to see the othere side of the dyno
-will the opti hold and not spark scatter at 2hp per cube
-will the dual pump make enough pressure for the Huge injectors??
Same bat time Same bat channel....!!!!
Old Jan 25, 2008 | 12:28 PM
  #102
TurboSS's Avatar
you said it brother
After the delay from the holidays I straped down and put in some OT for Ken the owner.
We want to ship his thing but doing GOOD work takes mad time.
I leave my house at 10AM and get home at midnight.
Heck sometimes I mow thru my dry earase board list and have to stair at it ....
whats next "you picky bi*ch"
I write a new list, load some tunes into my media player and get thrashing.
Old Jan 25, 2008 | 12:46 PM
  #103
blown383's Avatar
Good job! Can't wait to see some video of that beast running. My car is still in a million pieces... I may op to have you work on it. =(
-B
Old Jan 25, 2008 | 01:13 PM
  #104
TurboSS's Avatar
-B
let me finish this one and I would be more than happy to work on you ride!
Your welcome to drop buy the shop any time.
I'll give you the free tour :-)
If you want to call the shop and talk to Mike Haddad he would be more than happy to put you on tenative status.
At Haddad's each mechanic is assigned a car.
That is his car / responibility when ever that car comes in
I only have the long term and difficult cars. (bossis not shy about it. )
I can only do two at at a time.
Either parts are on order
parts are goin on the car
cars on the dyno
or the in house diff technition has it cause I blew up another rear with too much power again.
My jobs right now are:
Kens, 97 Z28 SS Snorkelface - built 355 FMIC raceport BOV PTK big turbo A4 - doomed diff - dyno soon
Marvins, 94 Z28 Green Machine - built 383 FMIC raceport BOV max pulley V1 Delteq M6 LS7 clutch -doomed diff - out of fuel @ 580RWHP @ 5100 RPM
ignition rev limiter in stock, and fuel system awaiting funds, then the diff is DONE CAKES
on deck
Waynes, 96' Impala SS - Race Prep 383 FMIC D1SC mild pulley delteq FLT 4l80e areomotive -10 eliminator insane paint - new diff is w/ customer for break in after dyno explodicuss @ 850+RWTQ @ 4500 RPM
this monster just eats parts on the dyno, wayne is skipping the 14's 13's 12's and maybe the 11's
buy the time he actually gets to drive it with out me putting disclaimers and rules on the car he might go staight to the 10's @ 4700 pounds
I have a two lift shop with a dyno to my self most days. The alignment parts, sales, service / modification shop have there own buildings.
Old Jan 26, 2008 | 02:36 PM
  #105
94'BLKBRD's Avatar
I plan on going turbo soon and I will not be ordering a PTK or any other kit.Im going to be getting RealQuick's hot parts,ebay cold side,ebay intercooler.Save some money and i'll know that I wont have to modify the hot parts.
