Turbo install *nightmare* PTK / PTS LT1 front mount
Old Feb 8, 2008 | 05:10 PM
  #166
formulaboy_95's Avatar
TurboSS - Was the rotor loose on that opti?
I have a new MSD Pro-Billet cap and rotor I am going to use with my install... I have one of the original MSD cap and rotors still on. Some have reported issues with the screws coming loose on the rotors, and the rotor rubbing on the housing on the MSD's. I haven't had a problem yet.
Old Feb 8, 2008 | 05:19 PM
  #167
snorkelface's Avatar
Originally Posted by TurboSS
Speaking of "back on topic"
IS there any other well documented PKT kits with dyno numbers? or posted graphs?
I really thought I could find more threads, but so far this is the closest one, but he is using a T70 instead of a T76.
Old Feb 8, 2008 | 10:47 PM
  #168
TurboSS's Avatar
Originally Posted by formulaboy_95
Looks like I am going to have to fab something up. The pics in this post are great. I am laying everything out before I attempt to install.
Do yourself a favor and get a used POS LT1 even if its dead.
Throw it on a stand and start maching things up on the stand.
Put every damm thing you can on the mach up motor.
Once it gets in the car your kinda screwed.
I completly dressed the motor on the stand including the K member.
Slid the whole shabang under the car and used the lift to drop the shell on the K. Then I litterly used a rubber mallet to tap the K into place via hitting the engine stand. Tand the K bolts in and was good to go in like 20 minutes.
Took forever to dress the motor and prep the shell! but only 20 minutes to pop it in the car. Then the nightmare of doing all the pluming began
Old Feb 8, 2008 | 11:45 PM
  #169
It probably would have helped if I posted the link!!!
https://www.camaroz28.com/forums/sho...light=ptk+dyno
Old Feb 9, 2008 | 12:19 AM
  #170
TurboSS's Avatar
No!
Old Feb 9, 2008 | 02:38 PM
  #171
GMRL's Avatar
No!
What were the plugs gapped at?
Old Feb 10, 2008 | 02:33 AM
  #172
TurboSS's Avatar
tell me what gap AND wht PLUG I whould run.....
Old Feb 10, 2008 | 04:28 PM
  #173
GMRL's Avatar
I would try NGK TR6s gapped at .035.
Colder plug and less gap for higher cylinder pressures.
Old Feb 11, 2008 | 12:52 AM
  #174
TurboSS's Avatar
colder and smaller
NGK BR7EFS @ .032
LeftoverChinese
Jan 14, 2024 03:03 PM
Fedesna
Nov 23, 2014 11:06 AM
Jul 4, 2005 05:00 PM
CamaroKiddZ28
Aug 7, 2002 10:17 PM
