a-trim any good
Old Aug 15, 2004 | 10:41 PM
shox9879's Avatar
a-trim any good
vortech A-trim any good
Old Aug 16, 2004 | 11:32 AM
zrg91gt's Avatar
Re: a-trim any good
Well, it was good enough to get my modded fox-body (H/C/I/E) into the high 11's.
13.7 @ 102 N/A
11.9 @ 113 Blown
Food for thought...
I was always told that the A-trims were too small, but it worked good for my car. Throw in a few more cubes though, and it might be a different story. (302 vs 350)
Old Aug 16, 2004 | 12:03 PM
'88Saleen's Avatar
Re: a-trim any good
The A trim is a good blower.With a small pulley it made 10lbs of boost and also got my car in the 11's.
Old Aug 16, 2004 | 06:02 PM
smokindastangs's Avatar
Re: a-trim any good
Do you think an A trim is too small for a 383?
Old Aug 17, 2004 | 07:11 AM
zrg91gt's Avatar
Re: a-trim any good
YES! Go to vortech's site and read the compressor maps. The A-Trim is working pretty hard to feed a hi-po 302, much less a 350 or worse yet, a 383. Think about it, if the A-Trim was capable of supporting those extra cubes, wouldn't vortech offer it as a base LT1 kit? If you ran it, you would have to spin it really fast, which in a nutshell equals much higher air temps, and less power.
Just my $1.25
Old Aug 18, 2004 | 12:33 AM
Flip94ta's Avatar
Re: a-trim any good
you can send your A-trim to vortech and they will upgrade it to a S-trim for around $800. you will need some serious pullying to get alot of boost (8+psi) on a 383. It depends on your set up and compression.
Magenta_Hearts
Mar 25, 2015 10:24 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
