super tight belt = problems ?
Old Sep 24, 2003 | 09:08 PM
V-2 SQ Jes's Avatar
those of you with super tight belts. are you having any problems ? such as :
idler/tensioner pulleys going bad.
water pump, p/s pump making noise/leaking
belts breaking
anything else
i'm wanting to know if i will have future problems.
also. how do you judge how tight your belt is ?
Old Sep 26, 2003 | 04:49 PM
ATMINF's Avatar
Overtightened belts will cause undue stress on bearings on the blower. This overtime will cause the blower to "loosen-up" and than then leans down the road to the blower going bad. Its hard to tell exactly what is "too" tight. I will put the belt on and tighten the belt up and then see over several runs how much the belt slips and then slowly adjust and tighten the belt, untill the slippage goes away. You must also remember that a new belt will also "stretch" a little(some are Very small others up to a 1/4 inch+). It is very little but after several heat cycles and actual driving it will need to be adjusted. Good luck.
Old Sep 26, 2003 | 06:46 PM
rskrause's Avatar
Moderator
There's a tool to measure belt tension. A buddy has one, which is real handy. Only probelm: it costs $125. If anyone is really interested I could get more info, but I won't see him until next week.
Rich Krause
Old Sep 26, 2003 | 08:11 PM
96 WS6's Avatar
Vortech blowers have spring loaded tensioners, one of the advantages of vortech... i don't think belt tension is a problem for a vortech blower.
Old Sep 27, 2003 | 01:50 AM
1LEThumper's Avatar
One other thing that can be a result of to tight of a blower is increased wear on blower bearings and crank bearings.
If you are using a ATI setup I HIGHLY sugguest SD concepts for a new tensioner.
Victor Lamb
Aug 26, 2017 02:52 PM
grabbem88
Feb 23, 2015 09:41 PM
NewsBot
Jan 8, 2015 11:29 PM
1LEThumper
Jul 14, 2003 12:45 PM
