stock map. How does the pcm add fuel for boost?
How does the computer know how much fuel to add as you start seeing boost? I have the stock map sensor and im curious if the car is tuned what they use to add fuel to 6 psi of boost.
Yep as mentioned above the MAF will add fuel up to approximately 450rwhp. The PE tables will add a percentage of fuel based on rpm after the MAF maxes. Once you get above 450 rwhp and your at WOT it is pretty easy to get proper fueling +- .3 AFR.
Fueling is pretty simple and easy with a MAF and one bar map, however the spark advance is impossible to account for boost. You can either pull all the timing at 100KPA(0 vacuum) or get a boost reference ignition box and pull timing linearly with boost.
I see you have a PCM4Less tune also. Have you looked at your spark tables? Bryan pulls plenty timing at WOT and incrementally in my tune.
Your datamaster will not show all the timing the BTM is pulling. It will show whatever Bryan pulled and thats it. The only way to see how much timing the BTM is pulling is with an old fashioned timing light and a compressor.
LT1runner
Aug 3, 2002 05:44 PM
LT1runner
33
Jul 24, 2002 01:19 PM
