Serious question about STS Turbo.
Re: Serious question about STS Turbo.
if the fuel gets too hot itll vapor and the car wont run. thatll happen well before it explodes. that wasnt a problem on the sts car i saw. since the turbo is in the back im sure the EGT is a lot cooler then an underhood kit. that would also explain why the car ive been around takes forever to spool up with a 402 compared to an underhood kit on a 302.
Originally Posted by NYSS Guy
There is the infamous 5.0THIS, I knew we wouldn't get along for long!!
Last I heard, it takes a spark to ignite fuel,
Originally Posted by NoStock
Check MSDS for gasoline autoignition or any compound.
The fact that you only posted one temperature is also wrong. Autoignition occurs at different temps for different octane ratings.
Originally Posted by scottslt1z28
dont listen to 5.0this........i have seen thousands of threads where he does nothing but bash the sts kit. I mean take what u want from him about it, but read his sig.
I'll say it one more time since you're too ****ing stupid to have seen it before when I posted it.... I didnt offer up my opinion on the kit.. some asked me, and I answered. Clearly people that dont like the kit shouldnt be listened to.. Only the people that love it.
Its okay 5.0. I value your response like anyone elses. I appreciate all the replies for my question. Thanks to all. Its not something i think about all to often, its just for piece of mind mostly. There are no stupid questions when it comes down to life or death.
There are at least 6 cars in Vegas with the rear mount turbo (most are custom, not STS kits). None of them have had problems with hot gas (vapor lock, fires, etc...).
Originally Posted by turbo_Z
Havent you ever heard of pre-ignition in gasoline engines? Hell diesel engines work on the principle of fuel ignition absent a spark source.
The thoughts that went through my head were more along the lines that the turbo (at least I don't think) would get nearly hot enough to heat through the heat shield, and heat the gas tank enough to explode. I just didn't think my response through before I posted.Hey 5.0THIS, I was only busting your chops in my post. Kind of a carry on from a different thread. Even though I don't agree with you doesn't mean you shouldn't post your opinion.
Originally Posted by RedBanditz28
I know this may sound dumb to most, but if it comes between asking a stupid question and dying, i choose stupid question. Being the turbo is mounted in the rear near the gas tank from what i heared, and there is only the heat shield protecting the gas tank, is there anything that can go wrong with turbo heating up the gas and the car would explode with me in it? I mean if hypethetically you get gas dripping down onto the hot turbo, will that start a fire or explosion?
Even if they is nothing wrong with the gas tank and just the fact that the turbo is near the gas tank, will anything or could anything happen bad?
Appreciate the help.
Exhaust gas should be extremely hot back there coparedto muffler.
PV = nrT
As the back pressure is higher in a turbo setup, the temp is also higher...thats what i believe anyway.
PV = nrT
I swear I read that the sts turbo doesn't get near as hot as an engine bay mounted setup because of its location etc. Could be wrong but either way I would get one of those kits without hesitation.
The air charge at the TB on an STS system is cooler than a front mount (non intercooled) but that's because the air travels a long way to the engine. I would imaging the rear mounted turbo itself is quite hot...I dare you to touch one!
Henson071
May 4, 2015 12:23 PM
guionM
39
Sep 3, 2002 09:16 PM
