S-trim to YSi?
Old Feb 29, 2008 | 09:09 PM
Badmire68's Avatar
S-trim to YSi?
I have a friend wanting to switch from his s-trim to a ysi on his 94 Z. I was wondering what all you have t change to make it work? Can you use the sme brackets? If anyone has any pics and some info it would be nice.
Thanks!
Old Mar 2, 2008 | 09:52 AM
Flip94ta's Avatar
The YSi is a pretty healthly blower for a big block, any reason why he want to go so big? A T-trim is good for 400-650 rwhp. Does he have plans to make more than that? The T-trim is a drop in replacement, the YSi would probably bolt up with some generic small block mounts but I bet there would be clearance issues with the factory serpentine belt set-up and the pulley will probably be where the electric fans are. Unless he is doing some high end 396 build I wouldn't run it, The power would be up top in the rpm band and it takes alot of HP to turn a bigger blower.
Old Mar 2, 2008 | 12:00 PM
Badmire68's Avatar
yeah he already makes 550rwhp with the s-trim @ 10psi. he looked at the t-trim upgrade, but wants to go with the YSi. He has plans to make around 850rwhp+. i have heard of a few people with the ysi on Lt cars. Just didn't know what they had to do to make it work.
Old Mar 2, 2008 | 12:54 PM
roguedriver's Avatar
I think the general consus when upping to the Ysi is a custom blower bracket vs the stock vortech brackets (the Ysi will bolt in) to keep the blower in there solid, and also to go with a big block hub on the crank along with getting the timing chain cover machined for the bigger hub and seal. Do a search on this forum. You'll find posts about it along with some pics too.
Ken R.
Old Mar 2, 2008 | 12:59 PM
cjmatt's Avatar
talk to victory racing, we worked together to design a bolt on ysi kit for the lt1 using the vortech cast aluminum brackets
Old Dec 29, 2008 | 04:19 AM
Highlander's Avatar
Care to post more about this setup?? Do you have pics?? what do they do about tubing?
97ChameleonTA
Dec 2, 2003 07:20 PM
StephenF04
May 16, 2003 08:48 PM
BOOST FED 95Z
Apr 12, 2003 07:52 AM
rskrause
Middle Atlantic
Dec 22, 2002 02:43 AM
