S-trim guys- with in please
Old May 5, 2003 | 06:54 PM
JD30thZ28's Avatar
Thumbs up S-trim guys- with in please
How many of you have moved your MAF to the boost side? Any pics?? Thanks
Old May 6, 2003 | 06:38 PM
TimChiaretto's Avatar
JD30thZ28,
Take a look at my web site, it shows the new tubes.
Old May 7, 2003 | 01:44 PM
JD30thZ28's Avatar
Thanks You have a very nice set-up , although I am going to be running without an intercooler but after looking at your pics I will probably get a new tube made to go from the Discharge to the MAF
Old May 7, 2003 | 02:26 PM
10secz's Avatar
I traded my s-trim/aftercooler for a ys-trim/air-air, so my plumbing probably won't help you, but I can say that the car runs very well with a blow-through MAF. Here's a shot of the MAF location:
http://para.noid.org/~lj/Alltogether3.jpg
Old May 8, 2003 | 11:04 AM
Chrisbequick's Avatar
Thumbs up
Wow, Tim. Nice setup! That's very clean. Did you simply swap the inlet and outlet on the intercooler and fabricate tubing, or was it more involved than that?
-Chris
Old May 8, 2003 | 11:38 AM
Camaro_SS/R's Avatar
I haven't done this yet, but is considering this one day when I get really bore. The following info was on the blown list, and it sounds like it will work well if you have an aftercooler or an intercooler.
You are exactly right. The people at Vortec indicated that this is why they don't locate the MAF in the blow thru position. They claimed the inlet temp in most instances would be too high and outside the range of the stock MAF/PCM boundaries. They claimed that this was their experience and the reason for locating the MAF at the inlet side for all of their kits. I found this not to be the case in my experience with my particular setup and thought this info might be of benefit to some.
Larry
To: <blown@lists.f-body.org>
Subject: Re: [blown] MAF relocation
Date: Tue, 6 May 2003 12:46:01 -0400
Reply-To: blown@lists.f-body.org
Gm MAF's are temp compensated. This is why it works some other brands are not and they have problems.
Mike
> Thanks especially to Brent M. my MAF relocation project is now
completed. I relocated the MAF from the inlet side at the air cleaner under the car in the position specified by ATI and moved it to the blow thru position near the throttle body. Vortec claims this is not a good position because the inlet air temp is too high for the MAF to work properly. Maybe this is true with their systems without an intercooler, but with the ATI system and the twin intercoolers this relocation turned out to be a major improvement.
Larry
Old May 11, 2003 | 10:25 PM
Chrisbequick,
Yes, I just swapped inlet for outlet on the intercooler. Without doing that I just could not make enough room to get the MAF located where it is. No other changes were made. It really was rather simple once I decided the intercooler didn't care which side was inlet or outlet.
Old May 12, 2003 | 12:39 AM
sleeperZragtop's Avatar
Johnny...when we go down to Portland..we'll look at Mike's set up on his 93'
davepl
Oct 23, 2003 05:51 PM
RealQuick
Aug 24, 2003 08:04 AM
StephenF04
May 16, 2003 08:48 PM
BOOST FED 95Z
Apr 12, 2003 07:52 AM
rskrause
Middle Atlantic
Dec 22, 2002 02:43 AM
