Pro-M MAF
Not sure.. I think its 80mm
the cool thing is that it can be calibrated to send a lower Hz signal to the PCM and thus avoid the max out.. you can tune around it and have a nice tune that will work.
shoooot. Ill have more in my stock PCM setup than my FAST setup (wideband stuff/impedence converter/MAF/maf converter)
highlander-
the first guy i spoke with said they had a GM MAF that woudl work, but he didnt have a effen clue what i was asking. I hung up, called back and got a diff guy that actually had a clue... he said this is the setup I need, and the converter box will come with a baseline curve programmed into it.
highlander-
ditto what 96 turbo said, and it is also programable.
MAFT will not do it. the MAF stops at abotu 471g/sec which means that anything above that it will not be able to tell the PCM/MAFT etc that more air is coming in.
Sounds very interesting indeed.
