Pro-M MAF
Old Apr 20, 2004 | 11:57 AM
  #31
stealth2's Avatar
yea, stock pcm.
Old Apr 20, 2004 | 12:01 PM
  #32
Highlander's Avatar
I just hope frequencies can be lowered and are lower than normal so you can have a better resolution of fuel and "tune" around it.. tricks... but if it works as it should.. IM happy about it.
Old Apr 20, 2004 | 12:04 PM
  #33
stealth2's Avatar
I don't like being on the forefront of this "idea." But, Pro M says it will work so . . .
Old Apr 20, 2004 | 02:22 PM
  #34
JordonMusser's Avatar
West South Central Moderator / Special Guest
do NOT trust pro-m! There stuff is good, but they dont have any idea what is going on as far as ls1/lt1 stuff goes. They speced mine out for me, and it was WRONG. I am going to send it back with DETAILED instruction on how I WANT it done, hopefully they dont try to use their brains too much :-/
Old Apr 20, 2004 | 08:35 PM
  #35
Highlander's Avatar
What specs and what hapenned?
Old Apr 20, 2004 | 08:41 PM
  #36
They tried to use their brains, instead of just listening to me.
I told them what I wanted, a 0-900g/sec maf with a 0-5v output.
they started asking me what injector sizes and ****, i tried to tell them it was irrelvalent.
Old Apr 20, 2004 | 08:44 PM
  #37
Highlander's Avatar
Exactly... So it can be scaled up to what you want...
I thought the PCM saw Hz not volts? Let me know.. but its a good idea if the maf has that resolution...
WOuldn't it be beter to have a 0-1024g/s in a 0-5v resolution? that way you easily scale the inj constant in half and have full control over fueling.
Old Apr 20, 2004 | 09:03 PM
  #38
it doesnt matter- because the MAF table will be 100% changes anyway(the response is different).
the PCM needs a freq input, but thats what a voltage to freq box is for :-D
Old Apr 20, 2004 | 11:29 PM
  #39
Highlander's Avatar
So... You still need the box.... How much for the box???
The idea of a TEC 3 starts to get more interesting.
Old Apr 21, 2004 | 09:28 AM
  #40
well, you can make one if you are cheap, or buy for 200-300ish.
Old Apr 21, 2004 | 03:39 PM
  #41
SMOKNZ's Avatar
Does anyone have any idea what the freq limit of our MAF's are? Or at what airflow they start to become inaccurate?
Bill
Old Apr 21, 2004 | 06:49 PM
  #42
Highlander's Avatar
I prefer to buy unles its easy to make
Old Apr 29, 2004 | 10:17 PM
  #43
Highlander's Avatar
TTT
Old May 3, 2004 | 10:51 AM
  #44
stealth2's Avatar
Bill
An LS1 maf will only read around 450 g/sec.
Old May 3, 2004 | 09:31 PM
  #45
SMOKNZ's Avatar
The computer can only read up to a certain frequency output that the MAF puts out, which can be programmed up to 510 gps. Undoubtedly the MAF will continue to output a higher frequency the higher the airflow goes above this limit. How much higher is what I was inquiring. A frequency divider would take care of the Maxing signal to the PCM, requiring PCM table modification of course. Thats what I'm working on right now. Was just curious if maybe someone placed one of our MAF's on some sort of flowbench and plotted a freq output vs. CFM. Thats kinda my next step, to see if a flowbench or something can flow enough air to test a MAF.
