Pro-M MAF
Old May 29, 2004 | 06:15 PM
  #46
Highlander's Avatar
Updates on this????
Old May 29, 2004 | 06:45 PM
  #47
stealth2's Avatar
Pro M is installed, will dyno within a week.
Old May 29, 2004 | 07:38 PM
  #48
92LT1RS's Avatar
Ok I'm confused. I understand that the stock MAF maxes out around 450 g/sec and that the PCM basically won't read any higher than that (correct?). By adding the new MAF to allow for boost, what do you do with the fuel tables under boost or do you use an FMU? And since you are using a stock PCM, did you get a higher rated MAP sensor? Does Tunercat or the like allow for modifying the fuel tables for higher MAP readings?
Old May 31, 2004 | 01:07 AM
  #49
Highlander's Avatar
Not quite...
The idea of a bigger MAF like the PRO-m is that the maf will not max out at the same Hz as the smaller maf... hence you will have a shift in "resolution" that way you can have "metered" air and tune around it...
The pro-m has an output voltage of 0-5v and it needs a converter.. im not sure if the one for GMs has the circuitry in Hz output.. which was one of my main concerns.
Old Sep 18, 2004 | 12:28 PM
  #50
Highlander's Avatar
Re: Pro-M MAF
Updates
Old Sep 20, 2004 | 04:52 PM
  #51
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: Pro-M MAF
the GM maf is still 0-5V out, you need the converter box. either make it, or buy it.
Old Sep 20, 2004 | 08:32 PM
  #52
Highlander's Avatar
Re: Pro-M MAF
Well if you have the converter then you can make it lower Hz Output?
Old Dec 6, 2004 | 07:06 PM
  #53
Mystic95Z's Avatar
Re: Pro-M MAF
Anyone ever get one of these to work??
Old Dec 7, 2004 | 01:04 AM
  #54
Highlander's Avatar
Re: Pro-M MAF
I have mine, but i have yet to install it... it comes with its own software AND converter... its really nice.. i could post pics if interested.
Old Dec 8, 2004 | 04:51 PM
  #55
TonyJ's Avatar
Re: Pro-M MAF
I'm interested. Are you trying to sell it?
Old Dec 8, 2004 | 10:35 PM
  #56
Highlander's Avatar
Re: Pro-M MAF
Nope!
Old Apr 16, 2005 | 12:23 PM
  #57
ProchargedLT1's Avatar
Re: Pro-M MAF
I know this is old but just wanted to see if anyone has the Pro-M MAF working? If so how well is it working,easy to tune..etc,etc...
thanks
Old Apr 16, 2005 | 01:12 PM
  #58
Highlander's Avatar
Re: Pro-M MAF
i have it... not yet working...
Old Apr 16, 2005 | 07:16 PM
  #59
streetbad's Avatar
Re: Pro-M MAF
Please post pics. Thank You, Tim
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
