fuel injector o-rings
Old Apr 7, 2003 | 04:11 PM
mineralwater's Avatar
Hey everyone -
recently, I found a vaccum leak in the fuel injector bungs - the o-ring on the firing side of the injecctor was "chipped", and a chunk of the rubber was missing. I'm pretty sure this caused a huge vaccum leak.
Anyhow, I had a couple spare o-rings lying around, but these o-rings were the ones that go into the fuel rail, not the o-rings that go onto the injector tip. I put it on to injector tip, and it was a little loose, but still fit ok. I installed it this way... but i'm still uncertain to as whether it sealed correctly, or didn't.
so my question is - can the o-rings be interchanged, or do I have to get a specific o-ring for the injector tip?
thanks.
Old Apr 7, 2003 | 06:00 PM
94F1Z28's Avatar
I think they are the same,i bought a set from GM and it came with 16 o-rings and they are all the same so i would assume they are for the top and bottom of the injecter.
Old Apr 7, 2003 | 06:01 PM
akafred's Avatar
im pretty sure they are the same. one way to tell is spray some wd-40 on the injector hole and if it revs up a bit you got a leak.
Old Apr 7, 2003 | 06:22 PM
madwolf's Avatar
They're the same. Just lube them with a little oil so that they go in smooth.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
