LT1 DIY Turbo Progress pics!
Old Feb 5, 2008 | 06:25 PM
  #16
LT1-TA's Avatar
Originally Posted by jsetzer
I would put it @ 8 inches away from the turbo in the downpipe. Mine is actually before the turbo and I have heard thats not ideal but I don't know why.
Downpipe is where most say. Wastegate shouldn't effect it as long as there are no leaks. It reads a ratio - so the amount of air flowing past it shouldn't matter.
I have a leak on my wastegate on the downpipe side, my preturbo side seals fine - so thats why my wideband read correctish - the dyno was off.
o2 sensors dont like all the pressure. And will fail faster in that enviroment(so im told). My wideband is about 9-10 inchs down the downpipe.
My stock o2's are in the crossover. But i doubt they last too long (speaking of, i gotta replace one now). I plan on going megasquirt and ditching them anyways hopefully soon.
Old Feb 5, 2008 | 08:26 PM
  #17
jammer94's Avatar
quick qustion as the system is coming together great just wanted to add on i hope you plan on supporting the weight of the turbo somehow with a bracket from the motor to the turbo or a brackets from the turbo to subframe off the car with some sort of cushion mount for vibrations of the engine unless you are running solid mounts i see most single turbo kits DROOP after a couple WOT passes due to the weight of the turbo and all of the piping...is that a t70 if so how large of a wheel are you running in the rear .81 .96 1.18 let me know....
but all in all cool beans brotha..
Old Feb 5, 2008 | 09:16 PM
  #18
LT1-TA's Avatar
Mine hasn't "drooped" yet. But I do plan on some sort of help holding the turbo up in the very near furture.
I think crackin pipes are the bigger worry when ya dont support the turbo. Definitly something that should be done on any setup that aint a got a log holding the turbo up
Old Feb 5, 2008 | 09:32 PM
  #19
Tricked-Out-Toy's Avatar
Its a .96 and Im running supports up from two free bolt holes on the block. I havent figured if I want to make it a welded connection to the main 3" log or have it so I can disconnect it from the brace. Itll depend on if I can get the header out easily with it as a welded connection.
thanks for the info on the WB. After the turbo makes alot of sense.
Old Feb 20, 2008 | 09:49 AM
  #20
c0rey's Avatar
Where did you get that reducer cone?
Old Feb 20, 2008 | 10:08 AM
  #21
I made it from a pice of 3" pipe. I cut a section close to the length I wanted and then cut a slice down the side, used a vise and slowly worked it into the cone shape, cut the excess off and welded down the seam. It took about 10 mins from start to finish.
Old Mar 10, 2008 | 09:44 PM
  #22
reamo04's Avatar
lookin good man. I just finished up my hotside yesterday, and am definately happy about ti
Old Mar 11, 2008 | 02:48 AM
  #23
jay_rich's Avatar
WOW its looking awesome....I wish i had the time to make my own logs.
I must say I LOVE your 3rd gen. I am doing a turbo setup in my 87 IROC also....just over the coarse of the next year....slowly buy the parts.
I have the C4 corvette headers that im going to flip and run 90* bends then down under the motor but try to tuck it under the motor as soon as possible so I dont have 2.5inch pipe running everywhere lol
Keep it up.
Also I noticed that ur building the motor with stock heads? I plan on the same. Are you going 355? If so what parts? I know the mahle -26cc pistons (which did u buy off that ebay add that listed the wrong alloy?)
Jay
Old Mar 11, 2008 | 07:27 AM
  #24
Your moving along a little faster than me. are you pulling the engine? cant remember if you said you had forged internals.
Jay
Thanks man! The car has been slowly getting to were I want it. its taken almost 10 years to figure out what that was!
The engine is a 355. Im doing splayed main caps. Using Pro-Grams caps. Eagle crank and Eagle H-beam rods (5.7") The pistons are the ones from Mahle. The should be here in a couple weeks. every person Ive talked to from Mahle says there 2618 so Im going to go on there word... The stock heads are the LE3's from Lloyd so they should support my goals, (~600hp). The cam is last on my list. not sure if im going to go custom or off the shelf....
Old Mar 11, 2008 | 11:33 AM
  #25
reamo04's Avatar
I will be pulling the motor after a while. Right now its a stock bottom end, but I am getting TRW pistons and scat h-beams after aw hile. I guess im not doing too bad for only being 18 years old lol
Old Apr 8, 2008 | 12:30 PM
  #26
where are you guys putting your exhaust temp sensors?
Old Apr 13, 2009 | 11:15 AM
  #27
Wow, I havent updated this is A LONG time lol all my pictures got delete/moved to rather than start a new thread, Im updateing the first post with the pictures that got moved and heres where Im at right now.
Intercooler and my MASIVE radiator mounted
Engine Bay and cage as it sits...
Old Apr 13, 2009 | 11:16 AM
  #28
Engine and NEW Turbo going with the TC78 rather than the MP 70 I had in the mock up pictures. also plan on makin 700+ instead of the 600 I started out wanting to make
Thats pretty much where Im at... Im smoothing the **** outa the engine bay and once thats painted the engine is ready to go back in! then its assembly time!! I cant believe Im about a month away from starting to put parts back on the car!
Old Apr 16, 2009 | 06:00 PM
  #29
jay_rich's Avatar
Well apparently u went all out lol...lookin good man! third gens FTW :P
Jay
Old Apr 27, 2009 | 08:16 AM
  #30
haha Ya its gotten a little nuts... I think im getting close to start bolting **** back on tho!
