View Poll Results: How much power on a Dynojet w/full tune (8-10psi)
425-500rwhp
31.25%
501-575rwhp
43.75%
576+rwhp
25.00%
Voters: 16. You may not vote on this poll
Let's play the guess my rwhp game!
Old Jul 26, 2009 | 05:00 PM
  #31
RealQuick's Avatar
Originally Posted by 97WS6SCharged
Are you using an aftermarket alarm with an ignition kill switch? You could always have the local parts shop test the starter before you replace it.
it had a GM Goodwrench alarm installed in 1996. Good idea about AZ testing it.
Old Jul 26, 2009 | 05:02 PM
  #32
RealQuick's Avatar
Originally Posted by 1982z28with18s
Just use a screw driver and jump the starter first, 2 minutes and you can rule it out.
If the key fob isn't working, battery could've died in it or might have a bcm issue. Does the security light flash when you try to start it?
that works if the solenoid is bad (I did it on my other shop car - auto tranny). However, doing it my manual tranny car didn't work.
Old Jul 26, 2009 | 05:03 PM
  #33
RealQuick's Avatar
Originally Posted by DirtyDaveW
Jon, don't give us that sh*t about being demotivated
Did your FOB get wet? Have you tried the Programming steps on the FOB just for grins? If you still think it's the BCM I have a good working one here you can try. If needed, I can priority mail it to you on Monday morning. I'm back in upstate NY so it wouldn't take long to get to you.
dave, the FOB never got wet, and I tried to reprogram... nothing happened. I believe I need the 96 BCM, is yours for your 96 specifically?
Old Jul 26, 2009 | 10:11 PM
  #34
DirtyDaveW's Avatar
Yes! I replaced it in an effort to see if that's what was causing my car to not start. Nope! I eventually found it to be the ignition switch (on top of the column, about halfway between the steering wheel and the firewall. Not the cylinder where you put in the key)
Gimme an address to send it to.
Dave
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
