How much power?
Old Nov 27, 2008 | 11:58 AM
LSWHO's Avatar
How much power?
With a basic bolt on lt1 and 6# boost off a "cheaper" SC kit? How much is average?
Old Nov 27, 2008 | 07:30 PM
RealQuick's Avatar
350-400rwhp.
Old Nov 27, 2008 | 08:38 PM
LSWHO's Avatar
So less than a head/cam package?
hmmm...
Old Nov 28, 2008 | 05:11 PM
slomarao's Avatar
maybe north of 400rwhp but I would worry about the stock block than. How many miles are on it?
Old Nov 28, 2008 | 05:35 PM
That Camaro Guy's Avatar
+1 for RealQuick
It's kind of a moot point though since it will probably not run longer than a year. Stock LT1 bottom ends are not made for boost. I gambled and lost after 10 months, then built a 383.
Old Nov 28, 2008 | 06:02 PM
LSWHO's Avatar
Originally Posted by That Camaro Guy
+1 for RealQuick
How much boost?
77k miles on the block.
Old Nov 28, 2008 | 08:33 PM
Showed 4psi on the gauge. I didn't blow a piston through my oil pan, I blew a head gasket and sucked coolant into my oil. The most common failure of a boosted LT1 is a failed piston ring land. I would suggest reading https://www.camaroz28.com/forums/sho...d.php?t=566122 if you haven't already. It's a great place to get started. I would also recommend staying away from "cheaper" superchargers as they are limited in what they can be upgraded for and are usually not as reliable. I blew up my motor with a Powerdyne and re used it after I built the new motor. I've had my motor running about a year and a half and I'm already pricing out another forced induction setup to make more power. Hope this helps
Old Nov 30, 2008 | 07:25 PM
slomarao's Avatar
you can make more power safer NA. A le3 setup, or AI's 200cc heads will do way better than 4-6psi of boost. Especially non intercooled.
Pretty much every guy in this section will tell you to rebuild it first. Theres a reason for it.
Old Dec 3, 2008 | 09:43 PM
dookie454's Avatar
I was at 6-7psi on stock motor, with headers no cats and magnaflow exhaust, with 1.6 ratio rockers that's it and I estimate I was at ~425-450hp.
I did some tuning myself, basically just reduced timing to avoid the spark knock which kills the stock pistons
Took it all apart when I took the heads off the get ported, bottom end looked brand new other than some carbon buildup... 115,000 miles.
Old Dec 5, 2008 | 03:01 PM
ramair96ws6's Avatar
8.5-9 psi for 5 years 36000 miles, motor is in a camaro now.
450rwhp
Mods
FLP headers
MSD BTM - 1 degree per pound of boost. 0 with 100 octane.
42# injectors
autolite 103s
taylor wires
everything else=stock
Old Dec 14, 2008 | 08:25 PM
fireman's Avatar
my car back in '01:
70k motor with Hooker shorties and a 4.5 PSI Powerdyne kit.
Zero PCM tuning, stock injectors, etc. Did run boost timing retard.
340rwhp/372rwtq through a 6spd with 4.10s. Saw about 5psi on gauge.
Stepped up to 6psi pulley and felt a noticeable increase in power, probably 30-40rwhp. Saw 6.5psi on gauge.
Then knock sensor went bad I guess, stopped pulling timing, and ringlands went south. Toasted my 70k factory stock shortblock that ran a 13.3 @ 106 mph before the supercharger.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
