How Much does a tight LSA REALLY affect a boosted motor
Old Oct 16, 2009 | 11:54 AM
  #16
4-RILLA's Avatar
Originally Posted by engineermike
Overlap with a blower and overlap with a turbo have completely different effects. LSA is irrelevant.
On a blower, you're trying to prevent losing air/fuel out the exhaust during overlap. On a well-tuned NA setup, you could actually lose air/fuel out the exhaust, so I believe this to be a credible scenario since you now have high pressure aggravating the situation. How much overlap is too much is up for debate, though, as no one who has done extensive testing shares the results.
On a turbo, the exhaust pressure is higher than intake, so you don't lose air/fuel out the exhaust. The danger is pushing exhaust into the intake port. However, the positive benefits of overlap seem to outweigh the negatives. As far as I know, no one has gained power from decreasing overlap with a turbo. In fact, the opposite has been the case, up to about +5 deg @ .050" at 2/1 backpressure/boost. The actual optimum overlap will depend on the backpressure/boost ratio, head geometry, etc., but again, if anyone knows the correlation between backpressure and optimum overlap, they aren't sharing.
About 30 years ago, David Vizard published a book that stated that supercharged engines needed higher LSA's than NA. Everyone assumed he meant 114 and it applied to turbo's too and ran with it. He actually stated that 110-114 should be considered (basing that on 106 being good for NA). Keep in mind that the audience 30 years ago wasn't as knowledgable as the today's FI enthusiast, and didn't know to include factors such as backpressure, actual overlap, etc...
Whoa, thanks Mike for the informative post, it is almost a "known" that you need a LSA of 114 for most applications, but it seems like in reality this is an ASSumed "known" number...and tighter LSA's will "work"..I think I am going to run my cam I made 412 RWHP N/A and 547 RWHP on the guns (automatic in an Impala 3800 stall) with and chunk -28cc dished pistons in there to get me around 9.25:1 and run 10-12lbs of intercooled boost, would imagine it would make at least 500-505...its cheaper than going solid roller (for me)...with the price I got the complete kit for ($2200 shipped) and could possibly make 500 and lil over 6 with the giggle gas...BUT IF a blower grind would be really beneficial..I am not oppsed to doing it, but just dont think this set-up will make enough boost to need it..but could be wrong.
Old Oct 20, 2009 | 08:03 AM
  #17
moehorsepower's Avatar
[QUOTE=engineermike;6141422]Overlap with a blower and overlap with a turbo have completely different effects.
Thank You...I cant believe no one said this. You are absolutely correct, Its not as critical on a supercharged application but does have a serious affect in a turbo application. I tuned a Turbo LT1 awhile back, Had a big nasty N/A cam and just would not make the boost / power it should of..Why? he was blowing most of the boost out the exhaust....
Old Oct 20, 2009 | 09:20 AM
  #18
jsetzer's Avatar
[QUOTE=moehorsepower;6144879]
Umm,, it was said back in post #5...
Old Oct 20, 2009 | 09:49 AM
  #19
4-RILLA's Avatar
Yeah and Moe...
Me and you have never met....but I am planning on you tuning this combo...says it right here in Line 13 of my mod list "Moe bailey tune"
LeftoverChinese
Jan 14, 2024 03:03 PM
Victor Lamb
Aug 26, 2017 02:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
