The High lift 224/236 Ex cam
Old Feb 18, 2005 | 07:05 PM
Schurters LT1's Avatar
This is the cam I am running in my 355 set up, BUT have a few ?
-What kind of rpm will this cam peak at...(heads AFR 210raceready out of box)
-I fig that the cam will hit the stock vavle covers...is there anything i cam do...(EMike I think hit his with a hammer) will this work , is there any pix out there, what can i do...
-I am thinking of using it with a 1.6 on both int/ex ....am i asking for @#$% here (i order the heads from AFR with spring for up to .625 HR)
-anyone have a half set of 1.52rr pro mag for 7/16 for sale.....
Old Feb 19, 2005 | 01:14 PM
engineermike's Avatar
Re: The High lift 224/236 Ex cam
The cam or rockers are not what hits the valvecover. It's the poly-locks, which will hit regardless of which cam you have.
Old Feb 20, 2005 | 09:49 AM
rskrause's Avatar
Moderator
With good supporting valve train parts you should pulley the blower to peak at ~6,000-6,200rpm.
Rich
Old Feb 21, 2005 | 11:22 AM
Could i make power to( or spin it too) 6500rpm, or because this is a EX cam it will fall off at 6200rpm
Old Feb 21, 2005 | 05:12 PM
My hp peak is at 6500 with this cam.
Old Feb 21, 2005 | 05:23 PM
EM, what springs do you have on your AFR210s....you make power up to 6500 then, falls hard or slow.
Old Feb 21, 2005 | 05:52 PM
Is putting a 1.6rr on the ex side a bad thing (.624) other then spring life....
Old Feb 21, 2005 | 05:55 PM
I'm running that cam with 1.6 on the intake and 1.52 on the exhaust.
Old Feb 21, 2005 | 08:42 PM
RealQuick's Avatar
Jeremy, check your pm's.
rideordie
Nov 5, 2019 04:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
1775.Z28
Jan 11, 2015 10:51 AM
