Got my 2 bar MAP installed Saturday
Re: Got my 2 bar MAP installed Saturday
Originally Posted by Schurters LT1
Is this something that needs to be done or is a nice to have thing, there is alot of cars that are making big power with the 1bar set up, so is the change worth it...
What level of power would this be good thing to do...is there more power to be found or just have more control over everything...would not DFI be the better way to go in the long run......
I'm going to make the assumption the stock map sensor is actually 1.75 bar like most other speeddensity cars.
The real solution to this problem (and I assume the guy who has the 'real' 2bar boost bin did this) would be to extend the tables beyond 100kpa. Thats what us honda boys did for their boost code (FYI I was into Hondas for a long time and this year got into Fbodys/GM). We just added 5 more columns and expanded the MAP scalars to include positive (aka boost) scalability. If anyone here is familier with the inner workings of the GM rom's, would it possible to just change the column values. IE cut vacuum resolution and change some to beyond 100kpa? Then you could keep the stock 1bar mapsensor, unless of course you wanted to go beyond 10-11psi (where a 1.75bar MAP begins to lose resolution).
I own a 93, so obviously I have a lot more vested interest in speed density operations. Also after owning and tuning turbocharged hondas for many years, tuning speed density is like second nature to me.
I already do the cut injector in half & VE tables trick...
So anyway... if anyone here knows if the column values can be changed, let me know
Yes the guy that did it, if he did it, he did extend the tables to 190kpa with the same resolution. He also extended the maf limitation.
he is one of the hptuners owners.
How was this done alittle more info
I don't have it.
He even deleted the thread on corvette forum, which i think i have it print or something.
I sent tunercat a couple questions about his software. I'm trying to figure out if TC reads the map scalars from the rom, or if TC just 'assumes' Column 1 = 20kpa, Column 2 = 25kpa, etc. If it is infact reading the scalars, thats promising and will make hacking this rom a lot easier.
If I get anything figured out, you can bet I'll post the rom/results free of charge for all on here.. I'm all about ECU freeware.
Highlander - how'd the pro-M maf work? I know the stang guys have been using them with great success, how'd your progress work?
I'd be incredible to get the lt1 ecu to read boost and eliminate the MAF issue. Dang... There's also the idea of using the SyTy ECU and piggy-backing it with the stocker, but I dont really like that idea. Easier with one ECU and get it done.
I thought about the SyTy ECU, but it all comes back to just hacking the stock code. An ECU is just like any computer, it only does what you tell it to.... must figure out how to tell my stock ECU to do my bidding
They deleted the posts from KEN from digital corvettes, but i think i have that page saved up somewhere
Victor Lamb
Aug 26, 2017 02:52 PM
[New Jersey] Cure those winter blues with the NJFBOA!!!
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
